Get Travel-Ready:Save Up To 18%!
by GL.iNet
Original price $39.99 - Original price $39.99
$39.99
$39.99 - $39.99
Current price $39.99
⚠️BEFORE YOU BUY
  • US Local shipments
MEET OPAL
Gigabit Wireless Router for Security-savvy Travelers
Cost-Effective Pocket Router
Opal (GL-SFT1200) is a pocket-sized travel router supporting 1200Mbps wireless transfers speed. It is compactly designed for portable use, which can meet the needs of wireless internet access for small businesses, small apartments or business traveler.
Max. 300 Mbps (2.4GHz) + 867 Mbps (5GHz) Fast Wi-Fi Speeds
Powerful CPU with 3 x Gigabit Ports
Excellent Security with VPN
Learn More
Your Security is Our Priority
Added Security to Help You Stay Secure on Public Wi-Fi
Opal (GL-SFT1200) at home
COST-EFFECTIVE GIGABIT ROUTER
The Perfect Wi-Fi for Small Apartments
With a minimalist and compact design, Opal is ideal for placing in small apartments, studios, and student dorms! The bright white color emits a sense of calmness, making it the perfect gadget for your private space. With VPN pre-installed, this gigabit router gives you fast Wi-Fi speeds as well as protection from surveillance and third-party trackers. Priced competitively, Opal is made for those who seek best-value.
Opal (GL-SFT1200) for your trips
SMALL-SIZED TRAVEL COMPANION FOR YOUR TRIPS
Stay Secure on Public Wi-Fi Anywhere
Opal is a pocket-sized travel router compactly designed for your next trip or adventure. Alongside its portable, compact design makes it easy to take with you on the go. You can use Opal to set up a repeater and create a secure Wi-Fi network in almost any location. Opal is an optimal choice for meeting the needs of wireless internet access for businesses or travelers. With Opal, you do not need to be worried about the cybersecurity threats brought by the public Wi-Fi network.
Opal (GL-SFT1200) protect your family & friends
SECURE NETWORK FOR MULTIPLE INTERNET ACCESS
Holistic Security - Protect Your Family & Friends
Just like other GL.iNet products, you can use four methods to access the Internet with Opal, including cable, repeater, USB 3G/4G modem, and tethering. It provides visibility into networking security while allowing for multiple access and controls. Simply create a personal Wi-Fi network and share it with your friends, family or colleagues during your trip. On top of its powerful supporting hardware, Opal provides you a secured network with OpenVPN & WireGuard®.
Connect More & Stay Fast
Support Max. 52 connected wireless devices simultaneously
No More Hackers, Access Network Securely
Opal provides the best encryption and authentication with OpenVPN & WireGuard®, just like the other GL.iNet products. Keeping your Internet connection private with multiple VPN protocol support. With our Web UI 3.0, you can set up a VPN server easily and access your files securely in a remote site as if you are at home.
WireGuard
Max. 65Mbps
OpenVPN
Max. 12Mbps
30+ Commercial VPN services provider
Runs on OpenWrt 18.06
Opal presents a user-friendly interface for common users to set up the router with minimal inputs, and an extended customization experience for advanced users to install plug-ins and applications. Opal runs on customized OpenWrt 18.06, supporting more than 5,000 ready-made plug-ins for customization. Simply browse, install, and manage packages within Opal's Admin Panel.
Cloudflare
PREVENT MAN-IN-THE-MIDDLE ATTACKS
DNS Encryption with Cloudflare
Opal supports Cloudflare DNS over TLS, it keeps users' online actions secure and private. DNS over TLS is a security protocol for encrypting and wrapping Domain Name System (DNS) queries and answers via the Transport Layer Security (TLS). The goal is to increase user privacy and security by preventing eavesdropping and manipulation of DNS data via man-in-the-middle attacks.
Cloudflare X GL.iNet
Opal (GL-SFT1200) Reviews
  • Video 0
    Use Home IP Address While Traveling with GL.iNet AX Slate, Opal, and WireGuard® VPN
  • Video 1
    GL.iNet Opal Travel Router Review: You Didn't Know You Needed This!
  • Video 2
    GL.iNET Travel Router Comparison - Beryl AX (GL-MT3000) vs Opal (GL-SFT1200)
  • Video 3
    Setup Tutorial | GL.iNet Opal Repeater Mode for Wireless VR
  • Video 4
    GL.iNet GL-SFT1200 Opal Review - The ULTIMATE TRAVEL ROUTER
  • Video 5
    GL.iNet GL-SFT1200 vs GL-AXT1800: Which Router is Best for Travel?
  • Video 6
    Using Playstation Portal & Travel Router Outdoors | Its Possible!
  • Video 7
    Travel Router For Playstation Portal | Bypass Mobile Hotspot Issues
  • Video 8
    WHY YOU NEED A TRAVEL ROUTER - HOTEL'S , CRUISE SHIPS, AIRPORTS..
    Dual-band Wi-Fi
    Dual-band
    Wi-Fi
    VPN Client/Server
    VPN Client /
    Server
    DNS Encryption
    DNS
    Encryption
    Type-C Power Input
    Type-C
    Power Input
    OpenWrt Pre-installed
    OpenWrt
    Pre-installed
    Gigabit Ethernet
    Gigabit
    Ethernet
    • CPU: SF19A28 Dual-Core, @1GHz
    • Memory / Storage: DDR3 128MB / SPI NAND Flash 128MB
    • Protocol: IEEE 802.11a/b/g/n/ac
    • Wi-Fi Speed: 300Mbps (2.4GHz), 867Mbps (5GHz)
    • Cellular: N/A
    • Battery: N/A
    • TF Card Slot: N/A
    • USB Port: 1 x USB 2.0
    • Ethernet Port: 1 x WAN port, 2 x LAN ports
    • Power Input: Type-C, 5V/3A
    • Power Consumption: <6W
    • Dimension / Weight: 118 x 85 x 30mm / 145 g
    • Opal (GL-SFT1200) (2-year Warranty)
    • Ethernet cable
    • User manual
    • 5V/3A Type-C power adapter US plug
    Frequently Bought Together🎁
    Category
    Product Initial Setup Guide
