Free US local delivery
Power Adapter Cable - Type-C PD to DC 5.5mm x 2.5mm (65W Max)
by GL.iNet
Sold out
Original price $9.99 - Original price $9.99
$9.99
$9.99 - $9.99
Current price $9.99
⚠️BEFORE YOU BUY
Description
Built-in PD Emulator Trigger with Type-C female. Seamless compatibility for Spitz Plus (GL-X2000) and Spitz AX (GL-X3000). It supports up to 65W maximum power output (backward compatible with 45W/30W/20W/18W), perfectly matching the power demands of your router for home, office, or travel use.
Specifications
Parameter
Details & Key Points
Input
Type-C Female, PD Charger
Output
DC 5.5mm x 2.5mm, Up to 20V (backward compatible with 15V/12V/9V)
Power
Supports up to 65W (backward compatible with 45W/30W/20W/18W)
Voltage
Requires PD charger with 9V-20V output
Cable Length
27cm
Compatibility
Spitz Plus (GL-X2000)Spitz AX (GL-X3000)
Caution
⚠️ Critical Notes for Safe & Stable Use
  1. PD Charger Wattage Requirement: Must use a 30W or higher PD charger (matches X2000/X3000’s 12V/2.5A = 30W rated power). Ensures sufficient redundancy and stable activation of the PD trigger chip (avoids unstable power or boot failure).
  2. Voltage Compatibility Confirmation:
    • GL-X2000: 9~36V voltage range → PD 20V output is fully compatible.
    • GL-X3000: 9~36V voltage range → PD 20V output is fully compatible.
  3. Mandatory PD Charger Use: Relies on PD trigger chip for high-power conversion. Non-PD chargers may cause unstable transmission or failure to work. It also supports 5V/1A or 2A charging.
Product Initial Setup Guide
Overall rating: 5.0 / 5 from 5 reviews.
AI Generated Review Summary
Summary topics
Review topics: [].
Review highlights
Reviews
Working great!
"Working great!"
Alex A. (5/5)
Convenient
"Lets me power my cellular router from my car. Works great!"
Conner W. (5/5)
Works
"I bought a lower price one on Amazon and it didn't work. This one worked perfect."
Frank A. (5/5)
Great idea
"This allows me to move my router close to a window where there is no AC power if I need to."
Glenn M. (5/5)
"Works great with my Puli AX. Now I dont have to lug around the old power brick and can use my own USB C PD chargers instead."
Anthony (5/5)
Q&A
