Free US local delivery
$129.99
$129.99 - $129.99
Current price $129.99
⚠️BEFORE YOU BUY
Meet Beryl 7
BE3600 Dual-band Wi-Fi 7 Travel Router
GL.iNet's Fastest VPN Dual-band Wi-Fi 7 Travel Router
As a fully upgraded version of our Beryl AX, Beryl 7 is a compact dual-band Wi-Fi 7 travel router that delivers the fastest VPN speeds (up to 1,100 Mbps via WireGuard®) in GL.iNet's travel router lineup. With PD compatibility, it can be powered using a standard phone charger cable, which not only reduces the weight and clutter in your luggage, but also makes it much easier to keep your travel router powered up. Capable of supporting 120+ devices concurrently-all in a sleek, portable design built for life on the go.
Fast Wi-Fi speeds: Max. 688 Mbps (2.4 GHz) + 2,882 Mbps (5 GHz)
Robust VPN performance: Max. 1,100 Mbps on WireGuard® and Max. 1,000 Mbps on OpenVPN-DCO
Streamlined travel convenience: Universal USB-C charging compatibility
Versatile high-speed connectivity: Dual 2.5GbE ports and support for 120+ client devices
Wi-Fi 7
3600 Mbps
Dual 2.5G Ports
Boosted Wired Connections
Blazing-Fast VPN
Max. 1100 Mbps
PD Compatible
for True Mobility
USB 3.0
AdGuard Home
Multi-WAN Failover
OpenWrt-based SDK
Flexible Customization
How Does the Beryl 7 Fit Your Life?
Connect All Devices for the Price of One
Why pay a separate internet fee for every device? The Beryl 7 is your key to significant savings on the go. Simply connect it to the paid network once, and then share secure Wi-Fi with your phone, laptop, tablet, and more-all under a single access cost. Maximize your connectivity while you minimize your expenses and effortlessly bypass the captive portals with a one-time setup-no repeated logins required.
*Note: Travel routers may be prohibited by some cruise lines. Please check the specific regulations of your cruise line before use.
Stream Your Home Media, Anywhere
With Beryl 7, any hotel room can become your private theater. Connect to the hotel Wi-Fi, activate the built-in ultra-fast VPN client to access your home server, and plug in your streaming device or smart TV. Instantly, enjoy your personal media library and stream 8K content at high speed with complete privacy—as if you never left home.
File Sharing for Family Trips and Team Travel
Beryl 7 makes media and document sharing effortless during group travel. Connect an external USB drive to instantly create a private network storage space, supporting 120+ connected devices simultaneously. Family members or team members can securely access and share photos, videos, and work files—without relying on unstable public networks or limited cloud services. Everyone stays connected through a centralized, secure hub, making collaboration and memory-sharing seamless wherever you go.
Remote NAS Access & Backup on the Go
With Beryl 7 acting as a VPN client, you can securely connect back to your home network anytime, anywhere. Paired with the Brume 3 (GL-MT5000) at home, it enables seamless remote access to your NAS devices, letting you manage files, stream media, or even perform real-time photo backups directly to your home storage. This setup ensures your personal data remains private and protected over encrypted connections, while giving you LAN-like access as if you were physically at home.
Drop-Free Calls, Anywhere You Roam
For digital nomads, a reliable internet connection is essential. Beryl 7 can turn any location—a café, co-working space, or beachside apartment—into a secure, productive remote office. It ensures crystal-clear VoIP calls and stable video conferences, while a dedicated guest network keeps your main connection secure for client collaborations.
Secure Access to Your Internal Network
For business travelers, accessing company resources restricted to specific office IP addresses can be challenging. Beryl 7 solves this seamlessly. Pre-configured with OpenVPN and WireGuard, it can act as a VPN client to securely connect back to your office network, giving you access to internal systems, file servers, or managed printers—as if you were physically in the office—all over a fully encrypted connection.
Versatile Connectivity for Uninterrupted Access
Never settle for weak signals. Beyond multiple connection methods—including Ethernet, Wi-Fi repeating, and cellular tethering—Beryl 7 is truly smart. Its advanced Multi-WAN feature provides automatic failover, constantly monitoring networks and switching to the best available connection to prevent drops. This ensures a robust, private network with the consistent high performance needed for gaming, 8K streaming and other data-intensive tasks.
Transform Your MiFi into a Powerful Home Network
Beryl 7 can turn your MiFi or smartphone data plan into a high-performance Wi-Fi 7 network. Simply connect via USB and activate tethering mode, and it will receive the cellular signal and rebroadcast it as a superior Wi-Fi network throughout your space. With support for over 120 simultaneous connections, every device enjoys stable, high-speed internet—eliminating weak signals and connectivity limitations once and for all.
Unlock Global Content in Your Dorm Room
Beryl 7 lets you and your roommates bypass geographical restrictions simultaneously using a single VPN account. Supporting 30+ VPN service providers, this compact router provides seamless access to region-locked streaming services and video game platforms across all your devices. It also lets you apply VPN protection to the entire network or select specific devices, eliminating the need for individual per-device VPN subscriptions while ensuring everyone can enjoy their preferred content without compromise.
Encrypted Remote Access for Traveling Homelabbers and Media Lovers
For homelab enthusiasts and media collectors who travel, the Beryl 7 ensures your entire home network is always within reach. By establishing high-speed encrypted tunnels via WireGuard or OpenVPN, it provides seamless, secure access to your home servers, development environments, and personal media libraries from anywhere. This eliminates the risks of public internet exposure while delivering LAN-like responsiveness, letting you manage critical services or stream your movie collection as if you were locally connected.
Wire-free Control for Wired Devices
Beryl 7 enables seamless wireless control for Ethernet-only devices through a simple setup: connect the device to the router's LAN port and use your smartphone or tablet for wireless management. This compact solution is ideal for digital audio systems, mini-PCs, PLCs, and other equipment lacking native wireless capability. With flexible uplink options including Wi-Fi relay, Ethernet/USB tethering, plus built-in VPN support for secure data transmission, Beryl 7 provides a complete connectivity solution in a minimal footprint.
Beryl 7 (GL-MT3600BE) Reviews
  • BEST Travel Router!
    BEST Travel Router!
  • Gl.iNet Slate 7 PRO Travel Router Revealed
    The Newest Travel Routers...
  • Gl.iNet Beryl 7, Comet 5G and Flint 3e Revealed
What Beta Testers are Saying
slide 6 to 8 of 7
Model Comparison
Beryl AX (GL-MT3000)
VS
Reliable Wi-Fi 6 for Basic Travel Needs
Positioning Positioning
High-value Wi-Fi 7 for Speed and Affordability
MediaTek, Dual-core @1.3GHz
CPU CPU
CPU CPU
MediaTek, Quad-core @2.0GHz
DDR4 512 MB / NAND Flash 256 MB
DDR4 512 MB / NAND Flash 512 MB
10/100/1000 Mbps
LAN Ethernet Speed LAN Ethernet Speed
100/1000/2500 Mbps
574 Mbps (2.4GHz), 2402 Mbps (5GHz)
Ethernet Speed Wi-Fi Speed
688 Mbps (2.4GHz), 2882 Mbps (5GHz)
Max. 300 Mbps
OpenVPN-DCO Speed (Via Ethernet) OpenVPN-DCO Speed (Via Ethernet)
Max.1000 Mbps
Max. 300 Mbps
WireGuard® (Via Ethernet) WireGuard® (Via Ethernet)
Max.1100 Mbps
Type-C, 5V/3A
Power Input Power Input
Type-C, 5V/3A, 9V/3A, 12V/2.5A
120 x 83 x 34mm / 196g
Dimension / Weight Dimension / Weight
120 x 83 x 34mm / 205g
OpenWrt Pre-installed
OpenWrt
Pre-installed
Tri-band Wi-Fi 7
Wi-Fi 7
VPN Client / Server
VPN Client /
Server
2.5G Ethernet Ports
Dual 2.5G
Ethernet Ports
USB 3.0 Port
USB 3.0 Port
Multi-Link Operation
Multi-Link
Operation
Partenal Controls
PD Power Supply
(5V/3A, 9V/3A, 12V/2.5A)
Partenal Controls
DNS Encryption
Technical Specifications
1 x LAN Ethernet port
1 x USB 3.0 port
1 x Type-C Power port
1 x Reset button
1 x Toggle button
Memory / Storage DDR4 512MB / NAND Flash 512MB
Wi-Fi Speed 688Mbps (2.4GHz), 2882Mbps (5GHz)
Antennas 2 x foldable external Wi-Fi antennas
Power Input Type-C, 5V/3A, 9V/3A, 12V/2.5A
Power Consumption <12W (without USB)
Dimension / Weight 120 x 83 x 34mm / 205g
Tools & Downloadables Firmware | App | Unboxing | Tutorials | Media Kit
  • CPU: MediaTek, Quad-core @2.0GHz
  • Memory / Storage: DDR4 512MB / NAND Flash 512MB
  • Wi-Fi Speed: 688Mbps (2.4GHz), 2882Mbps (5GHz)
  • Antennas: 2 x foldable external Wi-Fi antennas
  • Cellular: N/A
  • Battery: N/A
  • TF Card Slot: N/A
  • USB Port: 1 x USB 3.0 port
  • Ethernet Port: 1 x WAN Ethernet port; 1 x LAN Ethernet port
  • Power Input: Type-C, 5V/3A, 9V/3A, 12V/2.5A
  • Power Consumption: <12W (without USB)
  • Dimension / Weight: 120 x 83 x 34mm / 205 g
  • 1 x Beryl 7 (GL-MT3600BE) Router
  • 1 x User Manual
  • 1 x Thank You Card
  • 1 x Power Cable
  • 1 x Ethernet Cable
  • 1 x US Power Adapter
  • Converters (EU,UK and AU Plugs)
Recommended Bundle Purchase
Product Initial Setup Guide
Overall rating: 4.9444447 / 5 from 18 reviews.
AI Generated Review Summary
Summary topics
Review topics: ["size","design","setup","router","connection","features","performance","device","hardware"].
Review highlights
Reviews
Super useful
"Great. Especially being able to access it in the app and change settings remotely. I use it for pushing images from my remote cameras at sporting events."
Esther (5/5)
The "Home Away From Home"
"I needed a way to travel internationally while keeping my home IP address for work and banking. I paired the Beryl 7 with a GL-MT5000 (Brume 3) back at my house in Rochester, MI. This combo is essentially a "teleportation" device for your internet connection. The Performance is Real Wi-Fi 7 is great for future-proofing, but the real star is the quad-core CPU. When you’re running a heavy WireGuard tunnel, cheaper routers usually choke and slow your speeds to a crawl. The Beryl 7 handles it like a champ. I can hop on a hotel’s 2. 5G port and get nearly my full home speed over the VPN."
Adrian R. (5/5)
Great travel router with so many features
"The Beryl 7 is an amazing device. It can do so many things and I have only scratched the surface. So far, setup has been very easy when using my laptop to connect to the admin panel. I also love the VPN integration."
Kevin D. (5/5)
Small, lightweight, portable, powerful. I
"Small, lightweight, portable, powerful. I kind of like the Slate 7 a bit more, but this actually is a bit more powerful, a bit smaller, and less light in the night. Both incredible devices. If you need a travel router and don't mind or even like the color, this is the one to get!"
Christopher J. (5/5)
Amazing little (big) router
"The Beryl 7 (GL-MT3600BE) Dual-band Wi-Fi 7 Travel Router is an impressive piece of hardware that delivers both performance and portability in a compact, well-designed package. Right out of the box, its sleek, modern design stands out, with a clean finish and dual adjustable antennas that signal strong connectivity capabilities. Despite its small size, this router feels solid and well-built, making it ideal for frequent travelers or anyone needing a reliable networking solution on the go. Performance is where the Beryl 7 truly shines. With support for Wi-Fi 7, it offers significantly faster speeds and improved efficiency compared to previous generations. Whether you’re streaming high-definition content, participating in video calls, or managing multiple devices at once, this router handles it all smoothly. The dual-band functionality ensures stable connections, minimizing interference while maximizing speed, even in crowded network environments like hotels or airports. Another standout feature is its versatility. The router includes multiple ports, allowing for flexible connectivity options such as wired connections for added stability or sharing internet access across devices. This makes it perfect not only for travel but also as a backup home router or for temporary setups. The USB port adds even more functionality, enabling file sharing or powering additional devices. Setup is refreshingly straightforward, even for users who may not be particularly tech-savvy. The interface is intuitive, and the router can be configured quickly, getting you online in minutes. For more advanced users, there are plenty of customization options available, allowing you to fine-tune your network exactly how you want it. Security is another area where the Beryl 7 excels. It offers robust features to help protect your data, which is especially important when connecting to public or unfamiliar networks. This added layer of protection provides peace of mind whether you’re working remotely or simply browsing on the go. Overall, the Beryl 7 (GL-MT3600BE) is a powerful, reliable, and highly portable router that exceeds expectations. Its combination of cutting-edge Wi-Fi 7 performance, flexible connectivity, and user-friendly design makes it a standout choice for travelers and tech enthusiasts alike."
Rafael (5/5)
Fantastic Router, Easy to Set Up, Great Size
"As always, great product. I only buy GLiNet hardware when I can, the best products on the market, in my opinion."
Michael L. (5/5)
it works as inteende the
"it works as inteende the setup is eesy and performance sum times makes my home rounter seam slower the device it self is esey to careybut it dos heat up fast like a gameing pc so i reckumend you have this in a cold room"
Riley k. (5/5)
Great little travel router
"I could not be more impressed with this travel router! I’ve been holding out on getting one for ages thinking it wouldn’t be super useful. Well I couldn’t have been more wrong. Every time I travel I’m hooking up 3-10 devices (between my spouse and I) to insecure hotel WiFi. Well instead now I’m connecting a single device and done - that alone is worth it. Then I have it connect back to my home VPN securing all my traffic for both of us, she’s not as tech savvy as I am so she wouldn’t bother trying to figure out the hassle. Add to that it enabled us to play some co-op games together without real internet today and our travel day passed by super quick. If you’ve been thinking about getting a travel router, this is the device you want (and need)."
Ryan P. (5/5)
"Awesome"
Jeyka (5/5)
Easy setup and works like a charm
"I was impressed by its smaller size, it is noticably smaller than my older model Beryl. The setup went smoothly. My work requires that I travel quite a bit so I have to connect to public wifis often, so having another layer of security is very important and this fits the bill."
Douglas G. (5/5)
Q&A
