Get Travel-Ready:Save Up To 18%!
Original price $179.99 - Original price $179.99
$179.99
$179.99 - $179.99
Current price $179.99
15% off
Auto discount on add-to-cart
*Pack discount excluded
⚠️BEFORE YOU BUY
Flint 3e (GL-BE6500)
BE6500 Dual-band Wi-Fi 7 Home Router
The Smart Choice for the Wi-Fi 7 Generation
Flint 3e (GL-BE6500) is built for next-generation speed, stability, and security. Powered by dual-band Wi-Fi 7, it combines lightning-fast wireless performance with five 2.5GbE ports for high-speed wired connections. With advanced VPN support, plus built-in AdGuard Home, parental controls, and AstroWarp, Flint 3e delivers a seamless networking experience for smart homes, offices, and multi-user environments.
Blazing Fast Wi-Fi Speeds: Max. 688Mbps (2.4GHz) + 5764Mbps (5GHz)
High-speed Wired Connection: 5 x 2.5G ports
Powerful VPN Performance: Max. 680Mbps on WiredGuard® and OpenVPN-DCO
Flexible Expansion: USB3.0 interface
Wi-Fi 7
5764Mbps
5GHz
688Mbps
2.4GHz
Dual-band MLO
for Enhanced Stability
Up to 2500 sqft
Wi-Fi Coverage
Fast VPN Speeds
OpenVPN (with DCO support)
 & WireGuard®
5 × 2.5G Ports&nbsp
Boost Wired Connections
1GB DDR4
High-Speed Memory
512MB NAND
Flash Storage
Parental Controls
AdGuard Home
VPN Server & Clients
Wi-Fi 7
5GHz
5764 Mbps
2.4GHz
688 Mbps
The Next-Generation Wireless Experience
Powered by Qualcomm, Flint 3e takes Wi-Fi performance to the next level with Wi-Fi 7. Experience blazing speeds up to 6.5 Gbps, enhanced stability, and smarter bandwidth distribution for all your devices.
8K Streaming
Low-Latency Gaming
Online Meetings
Immersive VR & AR
Why Wi-Fi 7 Changes Everything?
Multi-Link Operation (MLO)
Stay Smooth, Stay Connected
Flint 3e uses Multi-Link Operation to combine or switch between Wi-Fi bands instantly. You get stable video calls, lag-free gaming, and faster downloads even when the network is busy.
4K QAM
Up to 20% Faster Speeds
More data packed into every signal means quicker file transfers, smoother 8K streaming, and lower latency across all your devices.
Multi-RU Puncturing
Smart Performance for Every Device
Flint 3e automatically optimizes bandwidth for multiple users, keeping all your devices fast and responsive, even in crowded networks.
Preamble Puncturing
Stronger Signal, Less Interference
By cutting through noisy frequencies, Flint 3e delivers faster, more reliable Wi-Fi, ideal for apartments, offices, and busy homes.
Wider Coverage That Reaches Every Room
Flint 3e delivers smooth, stable Wi-Fi that reaches every corner of your space. With coverage up to 2,500 sq. ft., you can enjoy strong and consistent signals across multiple rooms without dead zones or dropouts.
Flint 3e's High Capacity
Connect Over 100 Devices Smoothly
Flint 3e is built for high-capacity performance, supporting 100+ connected devices at once without slowing down. Smart TVs, laptops, phones, and IoT gadgets all stay fast and reliable, even in busy multi-user environments.
Connectivity Designed for Performance
Flint 3e delivers high-speed, flexible connectivity to keep your network stable, efficient, and future-ready. Whether for home, office, or professional setups, every connection stays fast, reliable, and optimized for your needs.
Flint 3e's Dual-WAN Flexibility
Stay online without interruptions
With a dedicated 2.5Gbps WAN port and the option to switch LAN1 into a secondary WAN, Flint 3e ensures continuous internet access even if one connection fails.
Load balancing
Failover protection
Flint 3e's Five 2.5G Ethernet Ports
Experience ultra-fast wired performance
The five 2.5G ports deliver top-tier wired speed and stability for your most demanding devices.
Lightning-fast file transfers
Low-latency gaming
Smooth 4K/8K streaming
Flint 3e's USB 3.0 Expansion
Expand your network effortlessly
The USB 3.0 interface lets you customize and extend your setup with high-speed accessories.
Share files or printers
Enable remote downloads
4G/5G tethering for mobile connectivity
Flint 3e's Multi-WAN Failover
Always-on connectivity
Flint 3e supports dual Ethernet WAN, Wi-Fi repeater, USB tethering, and cellular backup, keeping your network stable at all times.
Automatically switches to backup when one link fails
Prevents downtime for homes and businesses
Keeps bandwidth steady for heavy users
Connectivity That Fits Every Need
From small businesses to smart homes, Flint 3e adapts to your environment, delivering speed, stability, and flexibility wherever you need it.
Small Business Networking
Flint 3e Small Business Networking
With five 2.5G ports and dual-WAN support, Flint 3e powers multiple devices such as security cameras, printers, and workstations while keeping your network fast and stable.
DIY NAS Server
Flint 3e NAS Server Setup
Build Your Own Server with NAS
Transform your Flint 3e into a private server hub. Connect NAS devices via 2.5G ports for secure file backups, personal cloud storage, and seamless media streaming. Perfect for creators, remote teams, and small offices.
On-the-Go Connectivity
Flint 3e Mobile Connectivity
Use 4G/5G tethering to set up a secure Wi-Fi network in minutes, perfect for conference event, trade shows, or temporary offices. When broadband fails, Flint 3e keeps your business online.
Home Lab for Power Users
Flint 3e Home Lab for Power Users
Flint 3e’s developer-friendly OpenWrt platform lets enthusiasts run virtual labs, Docker containers, or custom network projects with advanced flexibility and control.
Fast, Secure, and Private Connections
Flint 3e supports 30+ VPN services with OpenVPN and WireGuard® in both client and server modes, giving you full flexibility for home, office, or travel.
WireGuard®
Max. 680bps
Max. 680Mbps
* Built-in OpenVPN-DCO acceleration ensures faster encryption and smoother performance for remote work, travel, and privacy-focused users.
30+ Commercial VPN Provider
Flexible VPN Modes for Every Need
Flint 3e gives you full control over how your VPN works. Choose between Global Mode for complete protection or Policy Mode for customized setups that match your lifestyle, whether you’re browsing, working, or streaming.
Flint 3e Global Mode VPN Protection
Full Network Protection
Connect every device through a single VPN tunnel for consistent security and privacy. Enjoy safer browsing, protection on public Wi-Fi, and unrestricted access to global content without exposing your data.
Benefits:
Anonymous browsing
Secure access on public networks
Freedom to bypass geo-restrictions
Flint 3e VPN Gaming Setup
VPN Gaming
Play your favorite games anywhere while keeping your connection fast and private. Access region-locked servers, reduce lag, and avoid ISP throttling or network blocks for smoother gameplay.
Benefits:
Access region-specific game content
Protection from throttling and attacks
Stable, low-latency performance
Flint 3e Secure Remote Work VPN Access
Secure Remote Work
Flint 3e supports both VPN client and server modes, ensuring secure communication between offices, homes, and travelers. Connect to your company network safely and protect sensitive data wherever you work.
Benefits:
Secure access to office resources
Encrypted data transfer
Reliable remote connectivity
Flint 3e Multi-VPN Policy Setup
Custom Multi-VPN Setup
Flint 3e runs multiple VPN tunnels at once, routing each device intelligently for optimal speed and privacy. Perfect for advanced users who balance streaming, work, and everyday use.
Benefits:
Streaming VPN tunnel for media access
Work VPN tunnel for secure business use
Bypass mode for maximum speed
Protect Your Family and Your Privacy
Keep your family safe and your data private with built-in tools that block ads, stop trackers, and create a safer online environment for everyone.
Flint 3e's AdGuard Home
Block Ads, Trackers, and Malware
Enjoy a faster, safer, and cleaner web experience with AdGuard Home built into Flint 3e. It blocks intrusive ads, stops trackers from following your activity, and protects against phishing and malware so your family can browse freely without distractions or risks.
Flint 3e's Parental Control x Bark
Keep Your Kids Safe Online
Flint 3e integrates with Bark to help you create a safer online space for your children. You can easily filter inappropriate websites, enable safe search, and set screen time limits to encourage healthy and balanced internet use.
Always Improving, Always Secure
Enjoy worry-free ownership with expert support at your fingertips and regular firmware updates that keep your router faster, safer, and smarter over time.
GL.iNet Continuous Firmware Updates
Help When You Need It
Get direct access to professional technical support at no extra cost. Whether you’re setting up, troubleshooting, or optimizing performance, our team is ready to help whenever you need it.
4K Video & Two-Way Audio
Smarter, Faster, More Secure Over Time
Flint 3e evolves with every update, delivering improved performance, stronger protection, and the latest features. Regular firmware updates ensure your router always stays optimized, reliable, and secure.
Simple, Fast, and Intuitive
Setting up and managing your Flint 3e router is effortless with GL.iNet’s mobile app and Web Admin Panel. Whether you’re a first-time user or a power user, you’ll have complete control over your network in just a few steps.
Flint 3e mobile app
GL.iNet App
Easy Setup with the GL.iNet App
Get your Flint 3e online in minutes using the GL.iNet mobile app.
Quick setup in just a few steps
Monitor real-time status and connected devices
Manage settings remotely with a clean, intuitive interface
Advanced Control via the Web Admin Panel
For users who want deeper customization, the GL.iNet Web Admin Panel provides advanced tools for total network control.
Full network configuration and monitoring
Detailed control of VPN, firewall, and connected devices
Accessible from desktop or mobile browser
Smart Network Management
Flint 3e GoodCloud Dashboard
Advanced Control for Power Users
GoodCloud gives professionals and network managers complete control across multiple devices or locations. Manage everything from one place with remote configuration, batch updates, and real-time monitoring that keep your large-scale networks running smoothly and efficiently.
Flint 3e AstroWarp Cloud Management
Smart Network Management in the Cloud
Flint 3e features AstroWarp, a secure cloud-based platform designed for remote management and site-to-site networking. Ideal for advanced users and organizations, it provides centralized device control, scalable performance, and future-ready hardware-level support for total network confidence.
What Beta Tester are Saying
Signal strength is solid. Compared to my old Wi-Fi 6 mesh setup, the Flint 3E holds up surprisingly well. I get strong, consistent signal across the house without needing extra nodes.If you’re looking for a powerful, customizable router that’s future-proof and easy to use, this one’s worth checking out.
@Bhanu P
The GL.iNet Flint 3e proves Wi-Fi 7 is ready for real-world performance—stable, cool, and fast. From a consistent 2.5 GbE LAN to Wi-Fi 7 wireless, it delivers enterprise-grade power in a home device. Built for speed, tested for stability.
@WickedYoda
When I tested the Flint 3e, I expected to find a less powerful Flint 3, but it turned out to be a pleasant surprise. The design is even better finished, and the durability has improved as well, especially for antennas.
@Ludovic C
The Flint 3e stands out for its effortless setup and dependable Wi-Fi 7 performance. Its dual-band connectivity provides excellent speed and coverage, while the OpenWRT platform offers deep customization for advanced users.
@Salim U
The Flint 3e delivers outstanding performance for home users who need reliable, high-speed connectivity in challenging environments. The setup was quick and intuitive, and the device maintained exceptional stability even during peak usage.
@Martin N
During testing, stability was rock solid. No IoT dropouts, no overheating, and the beta firmware never once crashed or rebooted. Even under a heavy load average of 8.16 for hours, the fan didn’t bother spinning up, and the CPU sat comfortably at around 65°C. That’s impressive thermal behavior for a router with this much capability.
@Vincent L
Flint 3E is a nice all in one powerhouse of a router. From the fast WiFI speeds to having Adguard Home and built in VPN capabilities, it can do it all! I'm able to hit full WiFi speeds maxing out my ISP performance of 1Gbps in all corners of my apartment, even through walls.
@Kyle F
Flint 3e is for users who want to maximize their 5 GHz network performance today while gaining some Wi-Fi 7 benefits at a more attractive price point, rather than investing in the 6 GHz ecosystem.
@AYKUT S
Even in the most remote part of my house the speeds are beyond sufficient. All of my IOT devices (can't believe how many I now have) are working without issue. I'm very happy and impressed with the performance with the Flint 3e.
@Lance F
If you're looking for a router that's fast, looks good, and can handle the latest WiFi 7 technology, the Flint 3e is definitely worth checking out. The speeds are excellent, it covers my whole house, and it's been rock solid reliable. Really happy with this upgrade!
@Mohammed S
Tri-band Wi-Fi 7
Wi-Fi 7
Multi-WAN
Multi-WAN
2.5G Ethernet Ports
2.5Gbps
Ethernet Ports
OpenWrt Pre-installed
OpenWrt
Pre-installed
VPN Client / Server
VPN Client /
Server
Multi-Link
Operation
AdGuard Home
AdGuard Home
Partenal Controls
Parental Controls
Specifications
Interface 1 x 2.5G WAN Ethernet Port
1 x 2.5G WAN/LAN Ethernet Port
3 x 2.5G LAN Ethernet Ports
1 x USB 3.0 Port
1 x Reset Button
CPU Qualcomm Quad-core @1.5GHz
Memory / Storage DDR4 1GB / NAND 512MB
Wi-Fi Speed 688Mbps (2.4GHz), 5764Mbps (5GHz)
Antennas 4 x Foldable External Wi-Fi Antennas
LEDs 1 x Dual-Color LED Indicator
Power Input DC5521, 12V/3A (5.5 × 2.1mm)
Power Consumption Without USB Load: &lt25W
With USB Load: &lt37.2W
Dimension / Weight 240 x 157 x 74mm / 848g
  • CPU: Qualcomm Quad-core @1.5GHz
  • Memory / Storage: DDR4 1GB / NAND 512MB
  • Wi-Fi Speed: 688Mbps (2.4GHz), 5764Mbps (5GHz)
  • Antennas: 4 x Foldable External Wi-Fi Antennas
  • Cellular: /
  • Battery: /
  • TF Card Slot: /
  • USB Port: 1 x USB 3.0 Port
  • Ethernet Port: 1 x 2.5G WAN Ethernet Port; 1 x 2.5G WAN/LAN Ethernet Port; 3 x 2.5G LAN Ethernet Ports
  • Power Input: DC5521, 12V/3A (5.5 x 2.1mm)
  • Power Consumption: Without USB Load: <25W; With USB Load: <37.2W
  • Dimension / Weight: 240 x 157 x 74mm / 848 g
  • 1 x Flint 3e (GL-BE6500)
  • 1 x Power Adapter
  • 1 x Ethernet Cable
  • 1 x Warranty Card
  • 1 x User Manual
  • 1 x Converter
Product Initial Setup Guide
