by GL.iNet
Original price $69.99 - Original price $69.99
$69.99
$69.99 - $69.99
Current price $69.99
⚠️BEFORE YOU BUY
  • US Local shipments
Slate Plus / GL-A1300
GL-A1300 Gigabit Travel Router
MEET Slate Plus
An Ultra Efficient VPN Encrypted Travel Router
Keeping Your Network Private During Travels
Slate Plus (GL-A1300) is a Wi-Fi 5 pocket-sized travel router with a powerful CPU optimized for network stability and processing VPN encryption efficiently. It includes our latest security features and runs on the latest OpenWrt operating system. It is designed for frequent travelers who have a heavy demand on using VPN networks.
Max. 400 Mbps (2.4GHz) + 867 Mbps (5GHz) Fast Wi-Fi Speeds
VPN speed of 28 Mbps (OpenVPN); 170 Mbps (WireGuard®)
A highly stable and powerful IPQ4018 @710MHz CPU
Learn More
Runs on OpenWrt 21.02
Slate Plus runs on the latest OpenWrt 21.02 operating system, with mass device connection capabilities, and significantly reduced signal interference. You can customize the router and install applications based on your preferences.
Fast and Secure Browsing with VPN Encryption
Supporting OpenVPN and WireGuard®, Slate Plus allows you to browse securely when on public wi-fi, work remotely when abroad, and access geo-restricted sites. Set up your VPN on the admin panel and shield the network on all connected devices. With saved settings, you won't have to set it up again every time.
WireGuard
Max. 170Mbps
OpenVPN
Max. 28Mbps
30+ Commercial VPN Provider
Block Ads & Tracking for Free
AdGuard Home Ready on Router
AdGuard on admin panel
Block ads for all client devices
Block online trackers and analytics by default
Block age-restricted content and services as needed
Customizable DNS filters
Keep sensitive online data safe
Enforce family browsing security
The Evolution of GL.iNet's Travel Routers
2017
Mango
(GL-MT300N)
Mango / GL-MT300N-V2
Mango
(GL-MT300N)
Our first mini travel router. Cost-effective and light to bring around. Comes with 4 GIPO for DIY fun.
2017
Creta
(GL-AR750)
Creta / GL-AR750
Creta
(GL-AR750)
Dual-band wireless router with expandable storage (128GB), and supports PoE (power over Ethernet).
2018
Slate
(GL-AR750S)
Slate / GL-AR750S
Slate
(GL-AR750S)
CES 2019 Innovation Awards HONOREE. Max.300Mbps (2.4GHz) + 433Mbps (5GHz) Wi-Fi speed and built-in MicroSD slot.
2020
Beryl
(GL-MT1300)
Beryl / GL-MT1300
Beryl
(GL-MT1300)
Advanced version of Slate. Provides top-notch security features and up to 400Mbps (2.4GHz) + 867Mbps (5GHz) Wi-Fi speed.
2021
Opal
(GL-SFT1200)
Opal / GL-SFT1200
Opal
(GL-SFT1200)
Cost-effective version of Beryl. Provides up to 1200 combined wireless speed; Ideal for traveling, small apartments, and student dorms.
2022
Slate Plus
(GL-A1300)
Slate Plus
(GL-A1300)
Our most powerful Wi-Fi 5 travel router since Slate. Supports OpenWrt 21.02 to provide unlimited ready-to-install packages.
OpenWrt Pre-installed
OpenWrt
Pre-installed
Dual-band Wi-Fi
Dual-band
Wi-Fi
VPN Client/Server
VPN Client /
Server
Gigabit Ethernet
Gigabit
Ethernet
Type-C Power Input
Type-C
Power Port
USB 3.0 Port
USB 3.0
Port
  • CPU: IPQ4018 Quad Core, @717Mhz
  • Memory / Storage: DDR3L 256MB / NOR Flash 4MB + NAND Flash 128MB
  • Protocol: IEEE 802.11a/b/g/n/ac
  • Wi-Fi Speed: 400Mbps (2.4GHz), 867Mbps (5GHz)
  • Cellular: N/A
  • Battery: N/A
  • TF Card Slot: N/A
  • USB Port: 1 x USB 3.0
  • Ethernet Port: 1 x WAN port, 2 x LAN ports
  • Power Input: Type-C, 5V/3A
  • Power Consumption: <6.5W
  • Dimension / Weight: 118 x 85 x 30mm / 181 g
  • Slate Plus(GL-A1300) (2-year Warranty)
  • USB cable
  • Ethernet cable
  • User manual
  • 5V/3A power adapter with US plug
Frequently Bought Together🎁
Category
Product Initial Setup Guide
