Limited-Time Flash Sale: Save Up to 20%!
GL.iNet physical eSIM GL.iNet physical eSIM
  • Supports 8 profiles
  • Supports most of esim profiles
  • Protect the privacy of personal information
  • Include US/EU 1GB+Global 100MB free data
$19.90
Secure
checkout
trust-footer
  • Free Shipping
  • 2-Year Limited Warranty
  • 30-Day Money Back Guarantee
  • Wrong purchase after opening or activation: No refund can be processed.
About eSIM
eSIM (Embedded SIM) is a type of SIM card chip integrated directly into devices, acting as a programmable chip that allows for the software-based configuration of data plans or phone numbers (eSIM profiles). eSIM offers greater flexibility and convenience, enabling users to easily switch carriers or change services without the need to insert or replace physical SIM cards. This technology is widely used in smartphones,wearable devices, tablets, and Internet of Things (IoT) devices.
To make eSIM technology available for routers and to address the complex production issues of chip soldering, as well as to provide customers with more options, GL.iNet has introduced a physical, removable eSIM card. The eSIM card from GL.iNet possesses the same functionalities and usage methods as an embedded eSIM chip.
Key feature for eSIM:
  • 4G/5G Compatibility: Supports 4G and 5G networks for reliable and fast connections.
  • Flexible Profile Management: Easily add, delete or enable eSIM profiles(up to 8 eSIM profiles).
  • Convenient Top-Ups: Select and purchase your preferred data packages from most eSIM stores worldwide at any time.
  • Global Compatibility: Works with eSIM profiles from most global eSIM stores.
  • Privacy Protection: Purchase eSIM profiles online without providing personal information, reducing the risk of privacy breaches.
  • Preloaded Seed Profile: Comes with a seed profile that includes 1GB of free data for the U.S. and Europe, plus 100MB of Global Data, valid for 1 year from the activation date.
  • Device Compatibility: GL-XE3000, GL-X3000 5G, GL-E750V2, GL-X750V2, GL-XE300, GL-X300B RS485, GL-X2000
  • Device Incompatibility: GL-RM1, GL-BE3600, GL-MT3000, GL-AXT1800, GL-AX1800, GL-MT6000, GL-SFT1200, GL-B3000, GL-A1300, GL-MT2500(A), GL-MT300N-V2, and GL-AR300M16(Ext), GL-S10, GL-S20, GL-S200.
Differences between normal SIM and GL.iNet physical eSIM
Description image
How Does eSIM Work with GL.iNet Routers
1. Insert the eSIM
If you're using a physical eSIM card, please insert it into the router. If you're using an eSIM chip, simply power on the device to begin.
2. Access the Admin Panel
Open the Admin Panel on your router and navigate to "eSIM Manage" under the Applications section.
3. Purchase an eSIM Profile
Purchase an eSIM profile online and download the provided QR code.
4. Download and Install the eSIM Profile
Use the Admin Panel to upload the QR code to your router, then download and install the eSIM profile.
5. Enable and Connect
Enable the eSIM card in the Admin Panel and enjoy seamless internet connectivity.
  • Traditional SIM
    Traditional SIM
    *Only available in US/EU
  • eSIM
    eSIM
    *For global use
Form Factor
A physical SIM is a small, removable card that must be inserted into a dedicated SIM card slot in your device.
An eSIM physical card looks like a standard SIM card but allows you to switch between different networks without needing to replace it.
Storage Capacity
Typically stores a single carrier profile and limited phone book entries.
Can store multiple carrier profiles, allowing users to switch between different carriers and plans easily.
Installation
Users need to manually insert or remove the SIM card to switch carriers or phone numbers.
Users can download and activate multiple carrier profiles digitally through Over-The-Air (OTA) updates.
Switching
Traditional SIM cards can be lost, damaged, or stolen.
Switching carriers or phone numbers can be done seamlessly through the device's settings without needing to replace a physical card.
Availability
Widely available and supported by virtually all mobile devices.
Increasingly supported by modern smartphones, tablets, smartwatches, and IoT devices, but not yet universal.
Video Guidelines
How to Set Up
Your eSIM with the
GL.iNet Router
for the First Time
Routers Compatible with GL.iNet eSIM
The firmware need to be updated to the newest version.
※Products with Quectel EP06-A modules do NOT support eSIM due to the software (from Qualcomm) lacking support for specific AT commands. For products with EP06-E modules, please refer to this LINK to upgrade the module's firmware and install the eSIM-supported firmware in order to enable eSIM functionality.
eSIM Cooperative store and Compatibility
The following stores are cooperating with GL.iNet. You can scan the code to purchase esim profile. All packages can be used on GL.iNet esim. If you have any questions, you can contact GL.iNet for after-sales or refund matters.
The following store list is tested by GL.iNet, but it is not guaranteed that all packages can be used. Because GL.iNet does not cooperate with these stores, GL.iNet cannot assist with after-sales or refund matters during the use of the package.
Supplier Network Type Min Package Typical Package 10G Typical Package 20G Typical Package 30G Max package URL
esim.me unknown 500M/1day/ $3.17 10G/30days/ $37.5 / / Unlimited/7days/ $21.4 https://esim.me
Redtea 4G 1G/1day/$0.98 10G/60days/ $19 20G/90days/ $30 20G/90days/$30 https://esim.redteago.com
globalyo unknown 500M/1day/ $0.69 10G/30days/ $9 20G/30days/ $17 / 50G/30days/$32.4 https://store.globalyo.com
easysim 5G 1G/7days/$5 10G/30days/ $26 20G/30days/ $43 50G/30days/$87 https://easysim.global
jetpac global 5G 1G/4days/$1 10G/30days/ $13 30G/30days/ $30 40G/30days/ $36 https://www.jetpacglobal.com
etravelsim 4G 2G/30days/$4.5 10G/30days/$15 / 50G/30days/$50
Unlimited/30days / $59
https://etravelsim.com
esim.sm 5G 2G/7days/$3.3 10G/30days/$13 20G/30days/$24.9 100G/60days/$108 https://esim.sm
Ubigi 5G 500M/1day/$2.9 10G/30days/$17 / / 50G/30days/$58 https://cellulardata.ubigi.com
T-mobile 5G 5GB/Mon/$15 / / / Unlimited/30days/ $60 Need to download T-mobile Prepaid esim app to purchase
airalo 5G 1G/7days/$4.5 10G/30days/$26 20G/30days/$42 / 20G/30days/$42 https://www.airalo.com
boost mobile unknown 1G/7days/$5 / / / 5G/15days/$20 https://boost.com.au/pages/esim
esim plus unknown 1G/14days/$4.9 10G/30days/$39 20G/30days/$119 https://esimplus.me
bytesim 5G 500M/3days/$3.9 10G/30days/ $17.9 20G/30days/ $31.9 30G/30days/$39.9 50G/30days/$59.9 https://bytesim.com
FAQ illustration
Frequently asked questions
Have you a question?
  • Can I use eSIM in different countries?
    Yes, eSIM is especially useful for travel. Many carriers offer international data packages, allowing you to easily download and activate global data services, avoiding expensive roaming fees. But not all carriers and countries support eSIM. It's recommended to check local support before purchasing a device.
  • How do I switch between different carriers?
    eSIM allows you to quickly switch between different mobile carriers. You can manage multiple eSIM profiles in your router web interface and select the service you want to activate.
  • Is eSIM suitable for travel?
    Yes, it's very suitable for travel. Users can purchase local eSIM data packages in different countries, avoiding expensive roaming fees.
  • Is eSIM secure?
    eSIM, through digital management, offers higher security compared to traditional SIM cards. It is difficult to steal or clone and supports strong encryption protection, reducing the risk of cloning and tampering. Therefore, eSIM performs better in terms of data security and device protection.
  • How many eSIM profiles can be added in an esim?
    The capacity of the eSIM profile and the storage space of the eSIM card are determining factors. GL.iNet's eSIM cards offer 380KB of usable space, and the eSIM profiles we have tested range in size from 10KB to 30KB. Currently, we have set a limit of 8 eSIM profiles per card, but this limitation will be lifted in the future.
  • Do the esim supports 5G network?
    Support is available, but it depends on the eSIM profile you purchase. Most eSIM stores currently offer 5G compatibility. For specific details, please refer to the product promotional page of the eSIM store.
  • Can I download esim profile multiple times?
    This primarily depends on the settings configured by the eSIM store vendor on their eSIM profile servers. The majority only allow for a single download, and any subsequent attempts will be rejected by the server.
