Get Travel-Ready:Save Up To 18%!
by GL.iNet
Original price $139.99 - Original price $154.99
$154.99
$139.99 - $154.99
Current price $154.99
10% off
Auto discount on add-to-cart
*Pack discount excluded
3G/4G Moulde: EM060K-G 4G Global / US+EU+UK+AU plug
⚠️BEFORE YOU BUY
  • US Local shipments
  • The cellular feature is restricted in Russia, Belarus, Cuba, Iran, North Korea, Syria, and the Crimean Peninsula due to modem limitations.
GL-E750V2
MUDI V2
Best Portable Wi-Fi Travel Router in 2024
CES 2020 Innovation Awards HONOREE
in the Cybersecurity and Personal Privacy product category
Portable 4G LTE Router
Mudi V2 by GL.iNet, is the best portable 4G LTE privacy router for road warriors and business travelers who want to secure their data and protect them from cyber criminals. With WireGuard® and OpenVPN settings, Mudi V2 gives the privacy-minded users a fast and simple VPN that utilizes state-of-the-art cryptography.
Supports 4G LTE, global carriers
Features VPN
Pocket-friendly
Supports failover, load balancing
Can last 8 hours per charge
Learn More
Pocket Wi-Fi on the go
Mudi V2 gives you a private bubble of internet wherever you go, with the added peace of mind that comes from knowing your online traffic is always protected by the VPN. With its support for global carriers, rest assured Mudi V2 works wherever the road takes you.
Runs on OpenWrt for Customization
A travel router that runs OpenWrt natively, Mudi V2 gives you full control of your network and the connected devices. Mudi V2 uses proprietary firmware based on OpenWrt (v22.03.4 Kernel version 5.150.176), offering over 5,000 ready-made plug-ins and applications at your disposal. Simply browse, install, and manage packages within the router's admin panel.
Best Travel Router with VPN
Protect your data with integrated VPN Client
Mudi V2 offers built-in VPN functionality to help you stay private and secure at all times. With its support for OpenVPN or WireGuard, the travel router protects your online traffic anywhere you go. All you need to do is get a VPN subscription from one of the over 30 VPN service providers supported by GL.iNet.
Built-in with VPN server for remote access
Mudi V2 supports running as a VPN server, allowing you to securely access your home or office network from anywhere in the world. The router supports running as a VPN client and a VPN server at the same time, meeting your needs all at once.
WireGuard
Max. 40Mbps
OpenVPN
Max. 5Mbps
Improved Network Reliability with Multi-WAN
Mudi V2 offers four connection methods—cellular, tethering, Wi-Fi, and ethernet. Featuring multi-WAN, the travel router supports failover and load balancing, ensuring uninterrupted internet connectivity wherever you go.
Cafe
Coffee shops
Whether you’re working from a cafe or just stopping by for a coffee, use Mudi V2 to establish a private internet connection and stay away from prying eyes.
Office
Hotel rooms
Hotel Wi-Fi is not always safe. Use Mudi V2 for a private, secure connection. Also, you can save on excessive Wi-Fi fees and avoid poor internet service.
On-the-Go
On the road
Mudi V2 meets whatever your needs are while on the road—letting you watch your favorite content, live stream, or access a network remotely.
Experience seamless connectivity with the Mudi V2, fully compatible with GL.iNet’s advanced eSIM solution, which supports both physical eSIM cards and integrated eSIM chips. eSIMs can be programmed remotely, offering unmatched convenience, flexibility, space-saving, and enhanced security. For consumers, this means effortlessly switching networks and avoiding roaming charges, while businesses benefit from centralized management, multi-device support, and secure data management.
Module: EM060K-G
LTE LTE-FDD B1/B2/B3/B4/B5/B7/B8/B12/B13/B14/B17/B18/B19/B20/B25/B26/B28/B29②/B30/B32①/B66/B71
LTE-TDD B34/B38/B39/B40/B41/B42/B43/B46① (LAA)/B48 (CBRS)
Up to 2 ×CA: B2+B2/5/12/13/29③;B4+B4/5/12/13/29③; B5+B5/7/25/30/66; B7+B7/12/26;B12+B12/25/30/66; B13+B66; B25+B25/26; B30+B29; B66+B29/66; B41+B41;
WCDMA: B1/2/3/4/5/6/8/19
①: B32 is only for secondary component carrier, B46 is only for secondary component carrier.
②: B29 is only for secondary component carrier.
③: means LTE-FDD B29 support receiving only, and is only for secondary component carrier in 2×CA.
Module: EM05-G
LTE B1/2/3/4/5/7/8/12/13/14/18/19/20/25/26/28/66/71/38/39/40/41;
WCDMA B1/2/4/5/6/8/19
Mudi V2 (GL-E750V2) Reviews
  • Video 0
    INTERNET ANÓNIMA MÓVEL E SEGURA EM QUALQUER LADO! | MINI ROUTER MUDI V2 4G LTE (GL-E750V2)
  • Video 1
    SHEIN è convenientissimo!
  • Video 2
    MUDI V2 Travel Router Review - This Router Is FAST!
  • Video 3
    GL-iNet mudi Portable 4G LTE Router GL-E750V2 Review
  • Video 4
    Mudi: Il Router Portatile 4G Che Rivoluzionerà il Tuo Modo di Connetterti!
  • Video 5
    GL-iNet Mudi V2 - Portable 4G LTE Router - Unbox & Review
  • Video 6
    How-To Setup Gl.iNet Mudi 4G LTE Wireless Travel Router Review
  • Video 6
    Le passeport pour un WiFi sans frontières : l’outil INDISPENSABLE des voyageurs connectés ? MUDI V2
    4G LTE Module
    4G LTE
    Module
    High Speed
    High Speed
    Dual-band Wi-Fi
    Dual-band
    Wi-Fi
    External Storage
    External
    Storage
    External Storage
    Built-in
    Battery
    VPN Client/Server
    VPN Client /
    Server
    Tor
    Tor Anonymity
    OpenWrt Pre-installed
    OpenWrt
    Pre-installed
    Global Connectivity
    Global
    Connectivity
    DNS Encryption
    DNS
    Encryption
    • CPU: Qualcomm QCA9531, @650MHz
    • Memory / Storage: DDR2 128 MB / NOR Flash 16MB + NAND Flash 128MB
    • Protocol: IEEE 802.11a/b/g/n/ac
    • Wi-Fi Speed: 300Mbps (2.4GHz), 433Mbps (5GHz)
    • Antennas: Internal antennas
    • Cellular: CAT4 / CAT6
    • Battery: Built-In 7000mAh Rechargeable Lithium Polymer Battery
    • TF Card Slot: 1 x MicroSD card slot (Max.1TB)
    • USB Port: 1 x USB 2.0
    • Ethernet Port: 1x FE LAN/WAN Port (Supported with the docking station)
    • Ethernet Speed: 10/100Mbps
    • Power Input: Type-C, 5V/2A
    • Power Consumption: Operating at full capacity: <6W(excluding USB external devices)
    • Dimension / Weight: 145 x 77.5 x 23.5 mm / 285 g
    • Mudi V2(GL-E750V2) 4G LTE router (2-year Warranty)
    • Power adapter
    • Converters (US, EU, UK & AU plugs)
    • User manual
    • Warranty card
    • Ethernet cable
    • USB-C port replicator
    • USB-C to USB-C cable
    • USB-A to USB-C cable
    • Pouch bag
    • Thank-you card
    Frequently Bought Together🎁
    Category
    Product Initial Setup Guide
