Free US local delivery
$129.99
$129.99 - $129.99
Current price $129.99
⚠️BEFORE YOU BUY
Meet Brume 3
MT5000 High-speed VPN Security Gateway
Wired Security Gateway for Home and SOHO
As the fully upgraded successor in the Brume series, Brume 3 is a high-performance wired VPN security gateway that brings DPI control to homes and small offices. It delivers robust multi-WAN connectivity and advanced security features to safeguard your devices and ensure seamless network operation. Achieving blazing-fast VPN speeds of up to 1,100 Mbps via WireGuard®, it offers exceptional performance for remote work and personal use. Housed in a vibrant, modern casing with convenient Type-C power input, Brume 3 stands as a powerful yet cost-effective networking powerhouse.
Extreme VPN Performance: Reaches up to 1,100 Mbps peak VPN throughput with WireGuard®, and up to 1,000 Mbps with OpenVPN-DCO
Tri-port Multi-Gigabit Connectivity: Features three 2.5GbE ports with flexible WAN/LAN configuration for maximum wired throughput
VPN Traffic Obfuscation: Masks VPN traffic to evade detection and overcome restrictive networks
Integrated Security Analytics: Includes free DPI detection for enhanced network safety and granular traffic analysis.
Versatile Expansion: Equipped with a USB 3.0 port for high-speed external storage or peripheral connectivity
VPN Server Performance
Up to 1,100 Mbps
Three 2.5G Ports
Boosted Wired Connections
Intelligent QoS
Prioritize What Matters
VPN Obfuscation
Disguise VPN Traffic
DPI-based Protection
Continuous Traffic Monitoring
Smooth SQM
Reduce Latency Under Load
Multi-WAN Failover
OpenWrt 21.02
Kernel 5.4.281
USB3.0 Data Port
Unleash Next-level VPN Power
Building on the trusted legacy of the Brume series, Brume 3 propels VPN performance to an entirely new tier. With hardware-accelerated OpenVPN-DCO and WireGuard®, it achieves breakneck speeds of up to 1,100 Mbps, delivering a seamless, lag-free secure connection. Whether you are accessing your home lab, transferring massive files, or shielding your entire LAN, the experience feels instantaneous. This is a massive evolution—over 3 times faster than the Brume 2 (GL-MT2500)—bringing enterprise-grade VPN performance into a compact, accessible gateway.
VPN
VPN
Brume 3 (GL-MT5000)
WireGuard®
Max. 1100Mbps
OpenVPN-DCO
Max. 1000Mbps
Trusted by 30+ VPN Partners
VPN providers partnered with GL.iNet
Enterprise-grade Security with Deep Packet Inspection
Leverage Deep Packet Inspection (DPI) to automatically filter malicious traffic, gambling sites, and malware, ensuring a secure network environment. Beyond automatic filtering, you gain granular control to manually block specific apps, domains, or IPs. With a continuously updated security database, Brume 3 stays ahead of emerging threats.
Brume 3's DPI-based Protection for safe browsing
Full Network Visibility via Real-time Dashboard
Gain actionable insights with a visual dashboard that monitors application usage in real-time. Track traffic trends over a 7-day period to spot anomalies or bandwidth hogs instantly. It’s the ultimate tool for households and small businesses to maintain total oversight of their network health.
 Brume 3's dashboard for traffic detection and management
Eliminate Bufferbloat with Smart Queue Management
Enjoy faster, smoother connections. Brume 3 features built-in Smart Queue Management (SQM) designed to combat bufferbloat. Once enabled, it keeps network latency minimal even when the line is saturated. Whether for video calls or streaming, SQM optimizes the traffic queue for every device on your LAN, ensuring a responsive connection during heavy usage.
Brume 3's SQM for Low-Latency Networking
Dynamic QoS for Application Prioritization
When bandwidth is scarce, Brume 3 knows what matters most. Dynamic QoS intelligently allocates resources, ensuring critical tasks like video conferencing and online gaming remain smooth while background downloads take a back seat. It balances traffic on the fly to maximize responsiveness across the board.
 Brume 3's Dynamic QoS for Smooth Performance
Stealth VPN Obfuscation
Brume 3 incorporates advanced VPN obfuscation technology to conceal the telltale signatures of VPN traffic, enabling it to evade detection by DPI (Deep Packet Inspection) systems. Traditional VPNs can bypass basic firewalls, but are easily blocked by DPI-based censorship systems. Obfuscated VPNs, however, work even on advanced firewalls that block standard VPN traffic. By effectively hiding the fact that you are even using a VPN, it reduces the risk of being flagged, throttled, or blocked, resulting in a more stable and reliable connection. This makes it ideal for bypassing strict regional controls or for anyone seeking enhanced privacy and consistent, uninterrupted access.
Wired Connectivity Excellence
Brume 3 delivers fast, flexible, and reliable wired performance to support every network setup.
Smart 2.5G Port Flexibility
2.5 Gbps WAN Port
2 x 2.5Gbps LAN Ports
Brume 3 comes with three versatile 2.5G Ethernet ports, giving you a fast and flexible foundation for any wired setup. The dedicated WAN port delivers full 2.5G performance and can also be reassigned as a LAN port, while LAN1 and LAN2 each support full 2.5G speeds as well, allowing you to tailor your network exactly the way you need it.
Whether you're optimizing for speed, expanding your wired devices, or setting up a secure home gateway, Brume 3 keeps everything running smoothly and efficiently.
Multi-WAN Failover & Load Balance
LAN1 can be switched to WAN.
USB 3.0 Port
Multi-WAN Failover & Load Balancing
Brume 3 lets you convert LAN1 into a second WAN port, enabling a robust dual-ISP setup with automatic failover to ensure your internet is always on. Intelligent load balancing across multiple links ensures seamless, reliable performance for NAS devices, media servers, and other high-bandwidth equipment in your home or small office.
Flexible 5V/3A Input for High Performance
Brume 3 is built with a dedicated Type-C power port requiring a 5V/3A power input, ensuring a stable performance for its high-speed features like up to 1,100 Mbps VPN speed and Multi-WAN. It offers maximum convenience by allowing the use of standard PD adapters for powering, simplifying your setup and ensuring robust network availability.
USB 3.0 Type-C for Easy Peripheral Connections
Versatile USB-C 3.0 Expansion
Brume 3 features a secondary Type-C port on the right side of the network ports, serving as a high-speed USB 3.0 data interface. This multi-purpose port supports 3G/4G/5G dongles for cellular backup and external drives for rapid data access. By delivering a 5V/2A power output to connected peripherals, it seamlessly enables a wide range of expanded functionality.
Build Brume 3 Your Way
Brume 3 combines robust hardware and OpenWrt architecture to let you build, customize, and control your network exactly the way you want.
Full Control Starts with OpenWrt
Powered by OpenWrt 21.02 (Linux Kernel 5.4.281), Brume 3 (GL-MT5000) is built for users who want full control over their network. With 1GB DDR4 memory and 8GB eMMC storage, it provides ample headroom to install packages, run services, and experiment freely — all on a compact, low-power platform.
One Device, Multiple Roles
Turn Brume 3 into whatever you need: a highly customized VPN gateway, a system-wide ad blocker, a lightweight NAS with external storage, or a DLNA media server. Its open architecture and robust hardware make it ideal for deploying advanced features powered by OpenWrt 21.02 or building a personal home lab without the cost or complexity of traditional servers.
A Gateway That Does It All
Brume 3 unites speed, security, and reliability—whether gaming, staying connected at home, running a small business, or building a private cloud, every connection feels smooth, safe, and effortless.
Brume 3 provides always-on home connectivity
Always-on Home Connectivity
Video calls stay clear, meetings stay on track—even if one connection drops. With Brume 3 quietly switching in the background, your home network keeps flowing seamlessly, so work, calls, and collaboration never skip a beat.
Gaming without limits with Brume 3
Game Without Limits
Consistent, responsive gameplay while everyone at home stays connected. Brume 3 dedicates priority to your gaming traffic with built-in QoS and SQM, so every match feels fluid, every reaction instant, and every win fully earned.
Brume 3 brings enterprise-grade VPN security for SOHO
Enterprise Power, Office Peace
The office runs with quiet confidence—remote staff connect securely, data flows seamlessly, and operations stay uninterrupted. Brume 3 brings enterprise-grade VPN protection to small businesses, keeping networks safe and efficient without subscription fees.
Brume 3 with OpenWRT for high flexibility
A Playground for Network Enthusiasts
Ideas flow freely at the desk—custom setups take shape, experiments run effortlessly, and every tweak responds instantly. Powered by OpenWrt 21.02, Brume 3 empowers tech enthusiasts with a playful, fully open network ready for exploration.
Brume 3 and Beryl 7 make a private cloud
Private Cloud at Home
Photos, files, and media move securely from anywhere to your home NAS, fast and invisible to prying eyes. With Brume 3 as your VPN server and Beryl 7 (GL-MT3600BE) connecting as a client, your devices form a seamless, private cloud—safe, swift, and effortless.
Model Comparison
Brume 2 Product Image
Brume 2 (GL-MT2500 / GL-MT2500A)
VPN Gateway with 2.5G Port
VS
Brume 3 (GL-MT5000) Product Image
Brume 3 (GL-MT5000)
Max 1,100 Mbps VPN Throughput
MediaTek, Dual-core @1.3GHz
CPU CPU
CPU CPU
MediaTek, Quad-core @2.0GHz
1 x 2.5G WAN, 1 x 1G LAN
Ethernet Port Ethernet Port
1 x 2.5G WAN, 1 x 2.5G WAN / LAN, 1 x 2.5G LAN
WAN Port: 10 / 100 / 1000 / 2500Mbps
LAN Port: 10 / 100 / 1000Mbps
Ethernet Speed Ethernet Speed
WAN / LAN Port:
Max. 150Mbps
OpenVPN
(Via Ethernet)
OpenVPN
(Via Ethernet)
Max. 1000Mbps (with DCO support)
Max. 355Mbps
WireGuard®
(Via Ethernet)
WireGuard®
(Via Ethernet)
Max. 1100Mbps
2.5G Ethernet ports
2.5G Ethernet
ports
USB 3.0 port
USB 3.0
Type-C port
DPI
DPI
Multi-WAN
Multi-WAN
VPN
VPN
Technical Specifications
2 x LAN Ethernet ports
1 x USB 3.0 port
1 x Type-C power port
1 x Reset button
Memory / Storage DDR4 1GB / eMMC 8GB
Power Input Type-C, 5V/3A
Power Consumption <5W
Dimension 75 x 92 x 25mm / 148g
  • CPU: MediaTek, Quad-core @2.0GHz
  • Memory / Storage: DDR4 1GB / eMMC 8GB
  • TF Card Slot: N/A
  • USB Port: 1 x USB 3.0 port
  • Ethernet Port: 1 x WAN Ethernet port; 2 x LAN Ethernet ports
  • Power Input: Type-C, 5V/3A
  • Power Consumption: <5W
  • Dimension / Weight: 75 x 92 x 25mm / 148 g
  • 1 x Brume 3 (GL-MT5000) Gateway
  • 1 x Power Adapter with a US plug
  • 1 x Ethernet Cable
  • 1 x Thank you Card
  • 1 x User Manual
Recommended Bundle Purchase
Product Initial Setup Guide
Overall rating: 5.0 / 5 from 16 reviews.
AI Generated Review Summary
Summary topics
Review topics: ["size","speeds","form factor","device"].
Review highlights
Reviews
Great small device!
"I’m using the router only as a load balancing tool. It works great using one 700MBs and other 600 MBs. The device looks great with a small site but very powerful."
Dalton I. (5/5)
Awesome!! Worth every penny!!
"This thing is fantastic. So small and descrete with high speeds for everything. I use wireguard from my phone and work, and this thing makes it super easy to setup. Plus, if you're more 'techy' you can also go into the openwrt interface for more advanced setting!! Great buy, great value."
MICHAEL I. (5/5)
Happy fan
"I had Brume 2 and I used it for several years. I used it as a home router with wireguard server. I had no single failure with it. When I found Brume 3 was out, I bought it and replaced the old unit - not because it was doing something bad, just wanted a newer device. I use Wireguard client and server and I so far zero issues."
Petar Y. (5/5)
Reliable, High Speed VPN
"The Brume 3 was just what we needed to improve our workflow. It was very easy to setup and performs perfectly. We now are able to access our NAS remotely and upload/download large files at high speed."
Philip G. (5/5)
VPN Speed!
"I specifically got this because I wanted to upgrade my home vpn connection from old router openvpn with 30mbs connection speed. Upon setting up as primary router and wireguard client i can get the full 5-600mbs connection speed through my vpn. I've been remote gaming through my pc and this connection speed is absolutely ideal! Love its compact form factor and powerful speed. Extremely happy and looking to upgrade my isp speed to allow even better connections. The multi wan feature is definitely interesting and I would definitely be using it provided i had multiple isp. Extremely happy with everything as my first purchase and will surely be back for more!"
Michael M. (5/5)
Very reliable and complete product for small labs or advanced home use
"The product employs OpenWrt, a well-documented and supported open source product. I was able to deploy WireGuard and Zerotier without incident. I was also able to configure multiple Wan connections to the Internet. There is a vast number of small optional network plugins available for the product. It is a great learning experience."
Finn N. (5/5)
Size and form factor are
"Size and form factor are great for my use in my portable mini server that I use everyday. Also shipping was great!"
Nathaniel V. (5/5)
Excellent speed throughput for wireguard
"Excellent speed throughput for wireguard in a form factor that is compact in size."
Stefan H. (5/5)
"Very prompt shipping and delivery. The Brume 3 is already hard at work securing my network, with me considering a second one already"
Ethan (5/5)
Setting up the router
"So far I like the new Brume 3. I am using it for the home router. I'd like better instructions on setting it up and how to implement VLANs to better secure and control network traffic."
Anthony T. (5/5)
Q&A
