FREE US domestic shipping on selected hot items
GL-S10 Bluetooth IoT Gateway | PoE Power Supply
by GL.iNet
Original price $24.90 - Original price $29.90
$24.90
$24.90 - $29.90
Current price $24.90
BEFORE YOU BUY
  • Enjoy FREE SHIPPING on all US local deliveries, with an estimated delivery time of 5-8 working days.
  • Products without the "US local delivery" tag are shipped from outside the US and are subject to shipping costs & longer delivery time.
Bulk Order
Other Purchase Channels
N/A
GL-S10 is an IoT gateway that supports BLE and Wi-Fi protocols, providing a simple and cost-efficient solution for transmitting BLE data to a cloud server. BLE supports GAP and GATT specifications and can be used as either Master-mode or Slave-mode to connect and exchange data with other Bluetooth devices. Besides, it can use Wi-Fi as a station to connect to a parent router, and it can also connect to the Internet through a WAN port. It has a built-in standard MQTT client that can connect to any standard MQTT server and forward incoming BLE messages to the cloud server.
> View USER MANUAL
Product Description:
  • Built-in Bluetooth Module: BLE communication distance is measured up to 80 meters (in an open and non-interference environment)
  • Device Filtering and Identification: Use our GL-S10 application to deploy and configure your BLE to MQTT transmission protocols.
  • PoE Power Supply: Supports 802.3at/af standard POE input power supply
  • Optional BLE Beacon Tag: Bluetooth Beacon is an optional accessory and can be used for indoor positioning, asset management and other scenarios. The rotating base makes the device easy to disassemble; and the base has 3M adhesive which makes it easy to fix in place. After turning on the Bluetooth switch at the bottom of the beacon, the beacon will broadcast BLE signals at an interval of 300ms.
NOTE:
*For bussiness clients, we support custom development to meet the needs of all kinds of MQTT server. Any relative request, please contact at <sales@gl-inet.com>
  • CPU: ESP32-D0WD
  • Memory / Storage: SRAM 520KB + PSRAM 8MB / NOR Flash 4MB
  • Protocol: IEEE 802.11 b/g/n
  • Wi-Fi Speed: 150Mbps (2.4GHz)
  • Antennas: SMA external antenna
  • Cellular: N/A
  • Battery: N/A
  • TF Card Slot: N/A
  • USB Port: N/A
  • Ethernet Port: 1 WAN port
  • Ethernet Speed: 10/100Mbps
  • Power Input: Micro USB, 5V/1A or PoE Power Input
  • Power Consumption: <0.5W
  • Dimension / Weight: 57 x 57 x 25mm / 53.6 g
  • GL- S10 Gateway
  • External Antenna
  • USB Cable
  • User Manual
  • BLE Beacon Tag (Optional)
PINOUT:
View PINOUT
