Save 33% Off on selected items, time limited!
Limited Bundle:Puli AX (GL-XE3000) | Wi-Fi 6 5G Cellular Router with Battery+Free SIM Card
Save 22% Save 22%
Original price $556.00
Original price $556.00 - Original price $556.00
Current price $433.68
$433.68 - $433.68
⚠️BEFORE YOU BUY
  • US Local shipments
Request a quote
*The included SIM card is more likely to be compatible with our device.
*The cellular feature in Puli AX (GL-XE3000) is restricted in Russia, Belarus, Cuba, Iran, North Korea, Syria, and the Crimean Peninsula due to modem limitations.
Key features for Limited Free SIM card:
  • UNLIMITED 5G & 4G LTE DATA: Include 50GB PREMIUM 5G speed DATA
  • PREPAID: $80/mo. with autopay at globaldatawifi.com . Tax and fees are included.
  • FULL USA COVERAGE - US mainland, Alaska, Hawaii, Puerto Rico, the US Virgin Islands, and other US regions as long as the T-mobile network is available
  • EASY SET UP - Activate via scanning the QR code or visit the link: https://store-us.gl-inet.com/pages/sim-active to fill out the activation form
  • SECURE CUSTOMER SUPPORT - We will help you solve any problems via instant chat and support email at support@gl-inet.com
  • No Contracts, Cancel Anytime.
Puli AX (GL-XE3000) is the ultimate Wi-Fi 6 5G Cellular Router that with a powerful built-in 6400mAh/7.4V/47.4Wh battery help you enjoy uninterrupted internet connectivity for even longer periods. GL-XE3000 is designed to offer Wi-Fi speeds of 574Mbps (2.4GHz) and 2402Mbps (5GHz), with a combined maximum Wi-Fi speed of 3000Mbps. It is designed for high-speed internet usage with a failover cellular connection, or for scenarios without a reliable source of internet, including recreational vehicles traveling in remote locations, or public transport within high-interference city limits.
Product Description:
Dual-SIM Standby: Puli AX has a dual-SIM slot design, allowing it to connect to the ISP with a stronger connection.
Multi-WAN: Puli AX features multi-WAN which lets users utilize multiple connection methods, including Ethernet, Repeater, Cellular, and Tethering, at the same time, increasing bandwidth and maintain better network stability.
Load-balancing: Puli AX's Load-balancing capabilities let users distribute bandwidth by custom proportion among multiple connection methods, prioritizing data consumption among preferred connection types, and minimizing network congestion.
Failover: Puli AX supports Network Failover and the option to configure Failover priorities among multiple connection methods. If the primary connection fails, the router will automatically switch to the next connection method without interruption.
Smart Charging & Battery Protection: Puli AX stops charging automatically at extreme temperatures (≤0°C or ≥50°C), resumes when safe and stop charging to protect the battery after 12 hours of full charge.
OpenWrt 21.02 (Kernel version 5.4): Puli AX runs on GL.iNet's latest SDK4.0+ firmware, supporting more than 5,000 ready-made plug-ins for customization. It presents a user-friendly interface for common users to simply browse, install, and manage packages with our no-code interface within the Admin Panel.
Remote Access and Management: Puli AX comes with GL.iNet's GoodCloud remote device management platform, it providing users with remote access to the device admin panel for maintenance and troubleshooting. It also enables batch device management, firmware updates, analytics and notifications for status updates.
DFS Certification in US, CA, EU & UK: Puli AX is approved to use DFS (Dynamic Frequency Selection), letting the router's 5GHz network use additional frequencies normally reserved by military, satellite, and weather radar applications.
  • CPU: MediaTek Dual-core, @1.3GHz
  • Memory / Storage: DDR4 512 MB / eMMC 8GB
  • Antennas: 4 x Cellular Antennas (SMA, 600M~6GHz), 2x Wi-Fi Antennas (PR-SMA, 2.4G~2.5GHz, 5.15~5.84GHz)
  • Cellular: 5G NR
  • Battery: 6400mAh/7.4V/47.4Wh
  • TF Card Slot: Max.1TB
  • USB Port: USB2.0 Type-A
  • Ethernet Port: 1 x WAN port, 1 x LAN ports
  • Ethernet Speed: WAN Port: 10/100/1000/2500Mbps LAN Port: 10/100/1000 Mbps
  • Power Input: DC5521, 12V/2.5A (5.5*2.1mm)
  • Power Consumption: <14W
  • Dimension / Weight: 155 x 95 x 49mm / 761 g
  • 1 x Puli AX (GL-XE3000) Router
  • 1 x Power Adapter + 4 Converters (US, EU, UK & AU)
  • 2 x Wi-Fi Antennas
  • 4 x Cellular Antennas
  • 1 x Ethernet Cable
  • 1 x User Manual
  • 1 x Thank you card
  • 1 x Wall Mount Kit
  • 1 x Free SIM Card
