FREE US domestic shipping on selected hot items
Spitz AX (GL-X3000) | 4G LTE CAT16 - Pre-order
by GL.iNet
Save 20% Save 20%
Original price $469.00
Original price $469.00 - Original price $469.00
Current price $375.00
$375.00 - $375.00
BEFORE YOU BUY
  • Enjoy FREE SHIPPING on all US local deliveries, with an estimated delivery time of 5-8 working days.
  • Products without the "US local delivery" tag are shipped from outside the US and are subject to shipping costs & longer delivery time.
Bulk Order
Other Purchase Channels
N/A
Spitz AX (GL-X3000) is a Wi-Fi 6 cellular gateway incorporated with the latest 4G LTE. Its dual-SIM card design and multi-WAN feature can help with enhancing your network stability. Spitz AX runs on MT7981A 1.3GHz dual-core processor to ensure the processing speed. The dual-band network with wireless speed 574Mbps (2.4GHz)+2402Mbps (5GHz), accommodates different needs under the same roof. It's compatible with OpenVPN and WireGuard, that speed up to 150 Mbps and 300 Mbps respectively.
Product Description:
In-vehicle network: Boasting six omnidirectional antennas for long-range and wall penetration, this router can provide reliable cellular reception in remote locations. The device can be conveniently deployed on the interior walls of recreational vehicles.
Uninterrupted RV Internet: Spitz AX (GL-X3000) is equipped with advanced features, including Multi-WAN, Load-balancing, and Failover, to ensure RV users experience quality internet connections when traveling in both rural and urban areas.
Network Storage & OpenWrt: Spitz AX runs on GL.iNet's latest SDK4.0+ firmware, supporting more than 5,000 ready-made plug-ins for installation. The local network storage feature supports SMB Protocol and WebDAV protocol. By plugging an external USB hard disc into the router, you can create a private network to store and share your documents.
Security & Privacy: Pre-installed with OpenVPN and WireGuard®. Spitz AX supports both DNS over TLS and DNS over HTTPS to enhance network privacy and security. It also automatically encrypts all network traffic within the connected network, hosts VPN servers, and supports VPN Cascading.
Remote Access and Management: Spitz AX provides users with data usage monitoring and technical support services with remote access to the device admin panel for maintenance and troubleshooting. It also enables batch device management, firmware updates, analytics, and notifications for status updates.
DFS Certification in US, UK, Europe & Japan: Spitz AX is approved to use DFS (Dynamic Frequency Selection), letting the router's 5GHz network use additional frequencies normally reserved by military, satellite, and weather radar applications.
  • CPU: MediaTek Dual-core MT7981A, @1.3GHz
  • Memory / Storage: DDR4 512 MB / EMMC 8GB
  • Antennas: 6 x Antennas (4×Cellular Antennas, 2 for Wi-Fi)
  • Cellular: 4G LTE CAT16
  • Battery: N/A
  • TF Card Slot: Max.1TB
  • USB Port: USB 2.0 Type-A
  • Ethernet Port: 1 x 2.5Gbps WAN, 1 x LAN
  • Ethernet Speed: WAN Port: 10/100/1000/2500Mbps LAN Port: 10/100/1000Mbps
  • Power Input: DC 12V (default adapter) / 24V
  • Power Consumption: <14W
  • Dimension / Weight: 155 x 95 x 36mm / 520 g
  • 1 x Spitz AX (GL-X3000) Router
  • 1 x Power Adapter
  • 2 x Wi-Fi Antennas
  • 4 x Cellular Antennas
  • 1 x Ethernet Cable
  • 1 x Warranty Card
  • 1 x User Manual
  • 1 x Wall-mount Kit
PINOUT:
View PINOUT
