FREE US domestic shipping on selected hot items
Refurbished | Beryl (GL-MT1300) Wireless Travel Router
by GL.iNet
Save 38% Save 38%
Original price $79.00
Original price $79.00 - Original price $79.00
Current price $49.00
$49.00 - $49.00
BEFORE YOU BUY
  • Enjoy FREE SHIPPING on all US local deliveries, with an estimated delivery time of 5-8 working days.
  • Products without the "US local delivery" tag are shipped from outside the US and are subject to shipping costs & longer delivery time.
Bulk Order
Other Purchase Channels
N/A
Note:
  • All refurbished products are officially certified and function perfectly.
  • All refurbished products are not included in the free shipping offer.
Tips:
  • Refurbished Beryl (GL-MT1300).
  • One-year limited warranty.
  • Refurbished products will be shipped from US.
  • Comes with packaging and accessories.
Beryl (GL-MT1300) is a high-performance next generation pocket-sized router that offers a powerful hardware and first-class cybersecurity protocol with unique and modern design. Beryl is the new era of travel router, an advanced version of our best-seller, Slate (GL-AR750S).
Product Description:
  • Excellent Dual-band Wireless Router: Up to 867Mbps (5GHz) + 400Mbps (2.4GHz) gigabit WiFi speeds. Support up to 40 wireless devices simultaneously. Tethering, 3G/4G USB Modem Compatible. Convert a public network(wired/wireless) to a private Wi-Fi for secure surfing.
  • Pocket-friendly: Lightweight design (184g), Small enough for travel, and powerful enough for apartments. Perfect for travelers, small businesses and family uses.
  • Keep your Internet Safe: IPv6 supported. OpenVPN & WireGuard pre-installed, compatible with 30+ VPN service providers. Pre-installed Tor service. Cloudflare, Supported. A toggle switch for VPN/Tor is also included.
  • Open Source & Programmable: Pre-installed the latest stable OpenWrt (19.07.4), backed by software repository. Allows you to install different applications, perfect for DIY projects.
  • Large Storage & Extensibility: DDR3L 256MB, NOR Flash 32MB. Up to 512GB MicroSD slot (TF card is not included in the package), USB 3.0 port, 3 Gigabit Ethernet ports. Extra storage brings a local drive to store your files.
  • CPU: MTK MT7621A Dual-Core, @880MHz
  • Memory / Storage: DDR3L 256MB / NOR Flash 32MB
  • Protocol: IEEE 802.11a/b/g/n/ac
  • Wi-Fi Speed: 400Mbps (2.4GHz), 867Mbps (5GHz)
  • Cellular: N/A
  • Battery: N/A
  • TF Card Slot: 1 x microSD card slot
  • USB Port: 1 x USB 3.0
  • Ethernet Port: 1 WAN port, 2 LAN ports
  • Power Input: Type-C, 5V/3A
  • Power Consumption: <8.65W
  • Dimension / Weight: 118 x 85 x 30mm / 184 g
  • Beryl (GL-MT1300) (1-year Warranty)
  • Ethernet cable
  • User manual
  • 5V/3A Type-C power adapter with EU+UK plug
